06-27-2022 12:52 PM
Hello! I am using the Serial Read and Write example VI given by labview. When I connect it to my serial port, in the response section, it says "ES" after I run it. I want it to read numbers from a lab weighing balance connected through serial port. So what do I do?
Image attached below!
06-27-2022 02:04 PM
What balance are you trying to talk to? Could you link to the user and/or programming manual so we can see the communication protocol?
06-27-2022 02:12 PM
Hello! Thank you for your response. The balance I am using is a Mettler Toledo ML4002E balance. Attached is the manual! Thank you again!
06-28-2022 07:24 AM
The *IDN? is not a valid command for this device. To get a reading you need to send "S".
06-28-2022 07:41 AM
By sending S, do you mean that my command should just consist of S?
06-28-2022 07:57 AM
Hi sheetalp,
No, not "just" S…
Read your manual for your balance! I can recommend to take a closer look at chapter 23.2!
06-28-2022 10:10 AM
That worked! Thank you!!
