"Breakeven point" for using AMC messages vs. FGVs to send/receive data
@abvenk wrote:
@crossrulz wrote:
@abvenk wrote:
What's AE?
Action Engine
So just another name for FGV.
We are getting into semantics that I have been fighting for YEARS.  I put the FGV as an AE that just has the Get and Set actions, making it functionally a global variable.  And if that is what you are doing, you are better off with an actual global variable.
Message 21 of 22
(587 Views)
Yeah, a lot of it is just semantics.  While my own internal thinking on the subject draws a bit fuzzier line than what crossrulz describes, I think his hardline definition is the most sensible and defensible one to try to adopt (or "enforce") community-wide.  It is utterly clear and that alone is a huge first step toward a shared understanding.
2 related things to add.  One is that there *can* be some debug usefulness to a pure FGV that only supports get and set operations.  A conditional breakpoint within the set case can help reveal which *caller* of the FGV has set the bad value that breaks the code.  You can't do that with a native global.
The other is that when the global data is a cluster, wrapping up access in a function call provides a mechanism to make "set" actions on individual cluster elements atomic.  See this current, ongoing thread for more info.
-Kevin P
Message 22 of 22
(579 Views)
