05-27-2010 08:13 AM
05-27-2010 09:13 AM
05-27-2010 09:29 AM
I'm not aware of a function that does this. I think the easiest way is to use the PtByPt Mean as a starting point to write your own PtByPt Array Mean vi. I think the vi isn't protected, so you can see the code. Save this vi under a new name (and not inside the vi.lib folder). Also note, that the PtByPt vi's are reentrant (VI properties).
Alternatively, if you need to change a lot of PtByPt VI's you could use VI Server and create references to n VI's.
Felix
