Hi Yi Y,
Thanks for your reply.
The attached files are the correct .wrl file and the one read from LabVIEW.
The colored is incorrect, the car is seperated to some parts, and the scale of some of the parts are wrong.
I think you can use any .wrl reader to read the wrl file I posted, all the reader I tried can read it successfully besides LabVIEW.
In the vi I have you can try to adjust the scale or rotate it then I think you can find the seperated car parts.
I will appreciate if you can give me any suggestion. Thanks,
-Alex
