08-08-2007 05:29 PM
I have recreate my sample file as a string constant (see attached code), I use "spreadsheet string to array" to form an array, however, it seems that the array I got is a 3 by 1 array, how can i get the 3 by 3 array?
Mike
08-08-2007 06:15 PM
08-08-2007 06:51 PM
Hi, I have changed the delimiter as "space constant", I can get the 3 by 3 array, but how about when the data source has more than one space, then i will get some empty column in the array, are there any way I can get the array without any empty column. attached is the modified code.
Mike
08-08-2007 07:36 PM
On the string palette, besides all of the fixed constants, is one just called String Constant. Place that on the block diagram and with the text tool inside the constant, press the space bar on your keyboard. If you need double spaces, press the space bar twice. If you need a different character, press that character on the keyboard.
08-09-2007 08:50 AM
