07-28-2015 11:39 AM
Hello I´m new in LabVIEW
I would like to generate 3 PWM signals using NI USB 6251, but I have only 2 counters..
I use the example of LabVIEW of this link http://www.ni.com/tutorial/2991/en/
but how can I generate the other pwm?
Besides I need to generate a specific number of pulses like 10
How can I do that? and how can I show the pulse in a waveform
Thanks!
07-28-2015 01:58 PM - edited 07-28-2015 01:59 PM
Hi ZelDrums,
sounds like you bought the wrong DAQ hardware for your task!
Which frequencies are we talking about? For low frequencies you could use software timing to generate a PWM: switch on/off a digital output pin with some delay in between…
Besides I need to generate a specific number of pulses like 10 How can I do that?
Well, generate a signal (aka waveform) consisting of your ten pulses. There are a lot of signal generation functions!
Please use proper LabVIEW terms. You probably want to show your signal (aka waveform) in a chart or graph: just wire your waveform to an indicator of your choice!
07-29-2015 11:19 AM
I didn´t buy the wrong DAQ hardware, I already had that hardware
but I found an example whe resolve my problem like send a number of pulses, I didn´t explain well
my ask was if is possible to generate a pwm without using counters?
Thanks!
07-29-2015 12:03 PM
07-29-2015 12:07 PM
there will be some example that can explain to me a little about how to do it?
thanks!!
07-29-2015 12:17 PM - edited 07-29-2015 12:21 PM
Hi Zel,
what's the problem with switching a DigitalOutput on and off with some delays in between?
Pseudocode:
repeat switch DO on wait (high time) switch DO off wait (low time) until break
The same as snippet:
You will find examples with the example finder and by searching in this forum…
