put the front panel in the pc screen
hi
can someone help me?
what i want is, when i run the programm i want to put the front panel in the screen, adjust to my pc scrren, can someone explain me how to do it?
(2,851 Views)
You can set the front panel size in the VI properties "Window size". Make the front panel cover your screen and select the "Set to current panel size".
(2,848 Views)
yes, but in this way i can move the window with scrollbars but, what i want is to take the window size, and cant move up down, left*right...
(2,840 Views)
Hi
Did you try unchecking 'Horizontal scrollbar visible' and 'Vertical scrollbar visible' in the 'Window Appearance -> Custom' screen?
Alternatively, You can right click on the scrollbar on the front panel window and select 'Off While Running' for 'Horizontal Scrollbar' and 'Vertical Scrollbar'.
Regards
Freelance_LV
TestAutomation Consultant
(2,830 Views)
