10-26-2012 11:47 AM
Much better with the DAQmx Task.
Wire "Data" directly into pulse measurements (you need the timing information!) and the pulse duration will be in seconds rather than in samples
10-26-2012 12:07 PM
Dear Jeff!
i try to do follow what u say! but i recieved ... no result!
this is my pic, show to u!
do u want my program ( *.VI)
help me! thanks!
10-26-2012 12:11 PM
It would be best to have the actual VI. Be sure to save the front panel defaults before sending on (Edit->Make Current Values Default).
10-26-2012 12:16 PM - edited 10-26-2012 12:18 PM
Check "Polarity" and "Export mode"
There isn't a full cycle of data so duty cycle can't be calculated
10-26-2012 12:20 PM
hii Crossrulz
i do that, but ... i have no more!
this is my program! help me check!
thanks!
10-26-2012 12:21 PM
hii Jeff
i check about that!
i have .... nothings, this my program!
help me
10-26-2012 12:21 PM
My program!
10-26-2012 12:53 PM
If you read the dt from the DAQmx data, what do you get. For some reason, the graph has 0 for the dt when I change it to a control. This could cause some problems.
10-26-2012 01:00 PM - edited 10-26-2012 01:01 PM
I also found that you want export mode to be "no period and duty cycle" and the polarity should be "low pulse".
NOTE: I only set the dt for the waveform because the graph was giving me a dt of 0. Coming out of the DAQmx Read should have a non-zero dt.
10-26-2012 01:03 PM
Dear Crossrulz!
i know, i have many problem in may program! but i do not know how to correct that!
help me! i need to finish this next week!
thanks! because this is first time i do with labview!
