03-29-2005 09:15 AM
03-29-2005
02:09 PM
- last edited on
01-21-2026
09:03 AM
by
Content Cleaner
You should digest the following document first, try its advice, and then follow up with details of any problem you still have:
How Do I Use Remote Panels with an Application (EXE) Built in LabVIEW 6.1? [broken link removed 1/21/26; article no longer available]
Your post was a little confusing because you didn't mention any LabVIEW version, any error codes, or other info that helps to explain what the actual problem might be with the non-compiled version of the code. It may be that there is a simple explanation that can solve that problem as well.
John
03-30-2005 06:59 AM
