property node chart
Highlighted
Hello, I am new to LabVIEW programming. I have a while loop where a chart is updated with values ​​from the RS232. The properties of this chart are defined in an outer loop. How I can do to refresh chart properties without leaving the while loop?. From what I can understand, if not get out of the loop where I am working, the properties are not updated if there was a change in them. If I put the definition of the properties within the while loop, the chart is not updated to the desired speed. My idea was to generate via a button, the refresh chart properties. How I can do?. thank you very much
Message 1 of 10
(864 Views)
Highlighted
Put the property node inside a case structure in the inner loop and make sure it only goes true whenever a property changes.
Can you show us some code? What properties do you need to write?
LabVIEW Champion. It all comes together in GCentral GCentral
Message 2 of 10
(853 Views)
Highlighted
Visual representation of what altenbach told
Message 3 of 10
(835 Views)
Highlighted
Please don't put words in my mouth. I did not suggest at all what you are showing here! Thanks!
Message 4 of 10
(816 Views)
Highlighted
I think the image below explains a bit what Altenbach described above.
Please correct me if i am wrong.
Plínio Costa
Application Engineering
National Instruments Brazil
Plínio Costa
Senior Techinical Support Engineer
Message 5 of 10
(795 Views)
Highlighted
I never said anything about a "refresh" button. 😮
I said "whenever a property changes". To see if the property node needs to update, you can compare it to the previous value using a feedback node. Here's a simple draft.
Note that the globally initialized feedback node start out with NaN to ensure that the property is written once at the beginning.
Message 6 of 10
(788 Views)
Highlighted
NaN is always Not Equal to NaN.
Ben
Message 7 of 10
(782 Views)
Highlighted
I would expect that the control is never NaN, thus resulting in an unconditional TRUE on first run.
In general, simply initialize with a highly unlikely value (-Inf, -1, 0, pi, etc.) as appropriate for the situation.
If you want, you can replace the comparison with "equal" and flip the two cases. Same difference. 😉
Message 8 of 10
(777 Views)
Altenbach, the ideia of a refresh button was wrote by DAScharf
Plínio Costa
Plínio Costa
Message 9 of 10
(766 Views)
Highlighted
"Please don't put words in my mouth. I did not suggest at all what you are showing here! Thanks!"
  Altenbach, Sorry for my misunderstanding
Message 10 of 10
(746 Views)
