01-31-2012 12:58 AM
I built a set of functions in a packed library. In that packed library I put my .mnu file.
I can manually add my packed library to the LabVIEW palette without any problem. It works.
Now I want to build an installer to distribute my packed library to the developpers in my company but I'm not able to insert the packed library programmatically into the LabVIEW palette.
Does anybody know how to do that ?
Christophe
01-31-2012 04:21 AM
I am working with NIcRio -9024 I have successufully interfaced NI9205 module , Now I want to interface NI9870 module with serial interface I am ttrying with the examples given in the website but they are not working can any one please send me small example of loopback interface with NI 9024 with NI 9870 serial module
rupesh
02-01-2012 03:51 AM
Hello Christophe,
This tutorial will guide you through the process to configure the build specification settings and build the packed project library:
http://zone.ni.com/devzone/cda/tut/p/id/3303#toc2
If you need further information, let me know.
Have a good day
02-01-2012 04:06 AM
hi thanks for reply
can you suggest me some method to just interface 9870 with cRio 9024 in loopback mode I am not getting it just simple example for loopback
rupesh
02-01-2012 04:22 AM
Sure we can answer your question and help you with your cRIO, but please, post it in the right forum:
http://forums.ni.com/t5/Real-Time-Measurement-and/bd-p/280
Have a good day
02-01-2012 05:20 AM
how can i post there is no option for new message ??
02-01-2012 06:09 AM
You can post by selecting a topic in the precedent link or you can use the next one:
I hope this helps.
Regards
