product of array
Hi!
Somebody help me with formula node:
How can I calculate the product of two arrays using a "formula node",I have tried using loops "for" but I have not obtained the correct result, moreover the vi remain in an infinite loop that does not allow me to close it.
I think that I do not write correctly the code of loops.
Greetings.
(2,779 Views)
Just see this example it has 2 solutions hope it helps you.
cheers
vicky
(2,771 Views)
You can also wire both arrays to the multiply numeric function and the result will be an array.
(2,766 Views)
Just an add on to UncleBump's reply..
The product function is of "polymorphic" thus you may simply input two numeric arrays to its inputs and recieve the product output as an numeric array.
Cheers!
ian.f
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(2,736 Views)
