processing of aquired signal during aquisition (arrays?)
I'm aquiring a voltage signal from a thermistor using DAQ and Labview. I'm using "for-loop" in Labview for that. Is it possible to take my previous readings of the voltage signal (through A/D channel), say, V(i-1), compare it to its current value V(i) and if a comparison condition holds - "freeze" V(i-1) and feed it continuously to a D/A channel,etc.
I'm basically trying to work with "arrays" in Labview, but can't get the voltage array previous values during the aquisition and manipulate with it during the aquisition.
Thanks.
(2,600 Views)
Kostya
To get at the V(i-1) value just use a shift register, then make your comparison and use a select. I'm not sure whether your array is for the history of one thermistor or several different thermistors. Take a look at the picture it shows both a single channel and 3 channels. To initialise the shift register you can do a single measurement before you go into the loop.
(2,600 Views)
Thanks, lanW. In fact, I tried to use the shift register, but results are same as if no shift register used. I checked it by wiring two "index array" icons with different indexes to the output of my "build array" - they give zero values - I monitor it by attaching "indicators" to the "index array" icons.
What do you think about it?
Also, where do I need to wire the right-hand shift register - to the output of the "build array" or to one of its inputs (one is the left-hand shift register, another one is my signal).
Thanks.
(2,600 Views)
It's hard to see where you are going wrong, maybe you could attach your program or an example which demonstrates your problem.
(2,600 Views)
