Try upgrading LabVIEW 6i to 6.0.2. You can also see if LabVIEW 7.0 evaluation has the problem. Finally, you may need to isolate the VI that is causing the problem. It may be corrupted and require copying its block diagram to a new VI to fix the problem with upgrading.
