problem with scc check in/out
hello,
i use the scc. now the vi is shown as checked in but i can't check it out. i also can't check it in or undo check out.
is it possible to get it free from the scc??
markus
(2,461 Views)
hi Markus,
found the following in DB:
"Problem Description:
I have my SCC configured with a LabVIEW perforce client. If I open the VI \examples\comm\access.llb\Retrieving Data from Access.vi and then from its block diagram open the subVI with a icons that says "2", then modify the sub VI, I don't get prompted to check the sub VI out. Howewver, if I close everything down and open the Part 2.vi from the GSW, then it does prompt for check out when I edit it.
Steps to Reproduce:
Make sure the prompt to check out SCC config option is set. 1. Launch LV. 2. Create a new project. 3. Add a VI to the project that is in SCC (not checked out) AND has a subVI that is also in SCC (and not checked out). 4. Open the VI from the project. 5. Go to the block diagram of the VI and open the subVI. 6. Edit the subVI. No prompt to check out is presented.
Workaround:
1. Explicityly add the subVI as an item under source. 2. Refresh the dependencies node after adding the main VI."
furthermore I found this link but I don't know if this will help...
greets!
(2,458 Views)
