problem with mod(x,y) in Eval y=f(x) VI
I can't seem to get mod to work in the Eval y=f(x) VI.  I entered "mod(x,20)" for a formula and get error -23001 "Syntax error of parser".  If I instead use "x-20*floor(x/20)" which should be the exact same thing, it works - no error.  Any idea what I'm doing wrong with mod?
(3,115 Views)
Accepted by topic author gharris
That function is not supported in the Formula Evaluation VIs.  In fact, no function of two variables is supported.  My usual workaround in similar cases is to use a little regex voodoo, in this case to replace the mod expression by its longhand equivalent.
You could also modify the Eval VIs to add the '%' function, which I did for the heck of it, but it is a jungle in there.
(3,105 Views)
aah - that explains it.  Thanks, and nice string parsing!
(3,078 Views)
