problem in conversion of file into array of proper format
how to do following
1) TO RETREIVE ALL THE SET OF STRING LOGGED
BETWEEN THE TIMINGS THAT IS GIVEN BY USER AS INPUT AND THE FORMAT TIMINGS OF IS BEING ATTACHED IN DEMO.DOCX
THIS IS ONE OF THE SET
RQ_TM::11:28:41
68556885844D13E9516
RS_TM::11:28:42
68B5B5688485A3E10C10000002D1800000000007F00C10000002D1800000000107F00C10000002D1800000000107F00C10000002D1800000000107F00C10000002D1800000000107F00C10000002D1800000000107F00C10000002D1800000000107F00C10000002D1800000000107F0F116
detailed problem is explained in document attached.
(3,303 Views)
Hi priya,
well, I would start to search for timing information. Then I would pick all lines between the requested timestamps…
I guess that is homework and you get some points/notes/grades for it. So please do your job on your own.
Ask for specific problems but not for general solutions!
(3,292 Views)
ok .....but can i know the way how to convert a file i attached into an array
(3,261 Views)
Hi priya,
what kind of array?
When using the ReadText function you will find an entry in it's context menu to switch it to read lines. Then you will already get an array of text lines…
(3,247 Views)
In labview 6.1  how to convert each line of a file into element of array of string type.
(3,207 Views)
Hi priya,
use SpreadsheetStringToArray…
(3,205 Views)
