prob in freqency of the acquired signal
Hi frnz,
      I have a prob in acquiring a signal. By using DAQ iam generating a sine signal and iam acquring the same. During the runtime
  i need to change the frequency. The Prob here is delay in changing the frequency. If the output sampling rate is 1000 then there
comes a delay in varying the frequency. If the o/p rate is 20k then immediate change in frequency occurs, but the frequency
acquired here is a multiple of 20 depending on the O/P rate.
  Eg:             generated frequency=10Hz
                                   O/P RATE : 1000 ==>acquired frequency  = 10Hz
                                   O/P RATE : 10000 ==>acquired frequency= 100Hz
                                   O/P RATE : 20000 ==>acquired frequency= 200Hz
                Please help me out with this prob...........
(3,528 Views)
u did not attach 2 Sub VIs required.
at what rate u r sending output and acquiring. If you are doing input and output simultaneously using the same DAQ card,  you should follow a relationship between sampling rate for input and output. Most of the DAQ boards use the same time base, so you can not acquire at the rate you want to.
Let me ask you few questions?
what is your output rate?
what is input sampling rate?
Are you using the same DAQ board for simultaneous Input and Output?
what is the sampling info you are giving to sine wave generator?
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,500 Views)
Hi Anil,,,,
output rate              :    20k
input sampling rate :     90k
yes i am using the same DAQ board(6215) for simultaneous Input and Output.(I am doing the loopback)
sampling info : Fs  = 1k
                       #s =  10k.
There are no sub VI's. You can run the program as it is.
(3,492 Views)
overshoot read DAQ1.vi
overshoot write DAQ1.vi
these VIs seems missing....
Many DAQ boards needs to maintain a relationship between Input and Output rate when done simultaneously. Output rate should be multile of input rate by 2 power "n"..n is an integer.
Keep the no.of samples in the "sample info" and output rate same..and try again....
do a simple example VI first, with simple acquisition and generation.
Anil Punnam
CLD
(3,483 Views)
K.Thanks Anil. I got the solution.
(3,475 Views)
got the solution...great.........what was the problem?.....wht did u fix?....it would be nice if u can post here...........
Anil Punnam
CLD
(3,472 Views)
Accepted by pani
hi. Here i attatched my VI.Go through tat.....
(3,461 Views)
