03-12-2007 04:07 AM
03-12-2007 04:44 AM
Probably, the formula node is calculating and passing a '0' value during the transition from 1 to 2.
But, it is difficult to suggest anything without looking at your vi.
Can you attach the concerned vi??
03-12-2007 05:25 AM
Thank you for the quick reply devchander. Attached is a screenshot of the VI. I cannot attach the VI since many VIs in the main VI are hardware dependant and will not work. There is some amount of time that passes between the appearance of one peak and another peak. At this point the meter goes down to zero. Hope you can help me find a solution to my problem.
Thanks and regards.
03-12-2007 06:09 AM
03-12-2007 06:48 AM
03-12-2007 07:17 AM
03-12-2007 07:26 AM
Thanks GerdW. Wonderful solution too!! Thanks again.
Regards.
