plug and play event of gige camera
Hi All,
I am using a Gige camera and want to capture the camera plug and play event, called Camera Attached and Camera Detached. I register the these two event. Here are two questions:
1  in event structure, for these two events, the specifiers are same: <Session Out>:PnP.  Is it right?
2  from my testing, only camera unplug triggers the right event.  How to capture the camera plug in event?
Thanks for any help.
Anne
(3,076 Views)
@Anne Zuo wrote:
Hi All,
... I register the these two event. ...
Hi Anne,
how do you register these events? Maybe you can generate a use event.
Mike
(3,064 Views)
I use "Register for Events" to dynamically register those two event.  Steps:
1 open camera, configure acquisition.
2 wire the session out to the event source of "Register for Events". You will see there are two events available: frame done, plug and play
From my experience, the frame done event works OK. I have problem with the second one.
Thanks.
Anne
Message Edited by Anne Zuo on 07-10-2008 02:06 PM
(3,056 Views)
Please continue this discussion under your original post on the Machine Vision forums, since this issue is specific to Machine Vision products. Thanks!
David G
Sales Engineer - SE Michigan & N Ohio
(3,029 Views)
