03-03-2009 06:50 AM
03-03-2009 06:52 AM
Give some more details.
Please simply don't say not working. If possible please post your code to help you better.
03-03-2009 07:08 AM
the attached vi and exe files , vi show the excel report but exe not show the report
03-03-2009 07:09 AM
03-03-2009 07:13 AM
Mukesh,
It looks like you are using the Report Generation Toolkit for MS Office. If that is the case, then there is a file that must be included during the .exe build. Varies slightly depending on version of toolkit. Refer to the documentation for the Report Generation Toolkit for MS Office for the exact details.
03-04-2009 12:16 AM
03-04-2009 12:22 AM
Is your problem solved? If so please mark centerbolt's post as solution to your problem, so that it will help others who are facing same problem and looking for a solution.
Mathan
