plot a graph on top of a previously existing graph
hello,
i have a graph inside a while loop that i'm using to plot and see real time my data points. after the while loop, i would like to fit a gaussian and plot its values on the same existing graph used previously for my data points. is this possible? thanks in advance and i would appreciate any help!
(2,014 Views)
It is possible to plot on the same graph. Use a local variable or value property node of Graph. You can right click on graph>create>propert node>value.
Hope this helps you.
(1,999 Views)
Here is an example of what GITA_A explained
Olivier L. | Certified LabVIEW Developer
(1,992 Views)
