Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
02-24-2018 01:31 AM
I try add DLL in Labview project.
but it seem still have problem
can anyone let me know if DLL install correct?
How to fix the project build problem?
see 3 attached files.
Solved! Go to Solution.
02-26-2018 04:24 PM
Hey zy6,
I was able to find a couple of articles from LTDI with some examples and instructions on using the dll. You can find them here:
http://www.ftdichip.com/Support/SoftwareExamples/CodeExamples/LabVIEW.htm
http://www.ftdichip.com/Drivers/D2XX.htm
There is also a long article with a similar question that I found here:
https://forums.ni.com/t5/LabVIEW/Labview-with-FTDI-D2XX-drivers/td-p/94458
Hopefully one these links can help you to move forward with your code!
VanCamp
Thanks!
We'll be in touch soon!
