07-10-2006 06:16 PM
hello,
Does anyone know which features to use if I want to import an avi
file and then play it without wmp? Also, I need to be able to analyze the video
in LabVIEW (specifically I will be measuring how far small fluorescent beads
will be moving). Here are the beginnings of my vi, but as you will see, I
really do not know which loops or sub vi's to use.
completely lost,
mgg
07-12-2006 08:58 AM - edited 07-12-2006 08:58 AM
Message Edited by Little A on 07-12-2006 09:01 AM
07-12-2006 01:33 PM
hi,
May you please clarify the second and sixth statement? I am not
sure where the unbundle icon should go or what should go in it or where the
wires should go afterward (I have only been using LabVIEW for three weeks, so
the more detail the better). I am having problems with the dispose image; are
there two different vi's for that, because it says that the data in the wire
from inside the loop does not match up. I have attached a new play video so you
can see if I am interpreting your suggestions correctly. I cannot tell you how
much I appreciate your help.
thanks,
mgg
07-12-2006 05:36 PM - edited 07-12-2006 05:36 PM
Message Edited by Little A on 07-12-2006 05:37 PM
08-02-2011 04:51 PM - edited 08-02-2011 04:52 PM
Is it possible to do this without a $3,599 NI Vision Development Module?
(P.S. I know this is an old 2006 thread. Any progress for the last 5 years?)
08-02-2011 05:32 PM
08-02-2011 11:27 PM
08-02-2011 11:46 PM
VideoLAN
Just click the link.
08-02-2011 11:57 PM
@zou wrote:
VideoLAN
VideoLAN is the name of the organization. Did you mean VLC?
08-03-2011 01:42 PM
If you meant VLC, do you have an example of controlling AVI animation, specifically frame-by-frame (one frame forward, and one frame backward)?
