02-24-2006 06:56 AM
02-24-2006 09:46 AM
02-24-2006 09:58 AM
02-24-2006 10:11 AM
02-24-2006 10:17 AM
02-24-2006 10:41 AM
02-24-2006 11:02 AM
I dont have WMP 10 at work here and our firewall does nto let us use the windows update site, so I will have to get back to you later on it.
have you tried going through the code to see what it entails?? The WMA.vi is a very simple case on how to use WMP in LV.
In order to modify that VI for WMP 10 (it used WMP9.0) you would just have to go to your control pallete .Net and ActiveX pallete> Windows Media Player Control on the front panel. Then create property nodes like the ones in the VI and you should be all set.
i will try to work on it over the weekend and get back to you, but if you can work through it today it will be much quicker.
Kenny
02-24-2006 11:29 AM
I was able to get WMP 10. The WMA.vi worked for me.
Did you get any sort of error or would it just not run?? (more information is never a bad thing)
The user was using LV7.1-8.0, which means it should work jsut fine with your system.
02-24-2006 11:44 AM
02-24-2006 01:08 PM
