05-24-2011 08:26 AM
Dear all
How can I play and control a music in LABVIEW?
Thanks in advance
Muhammad Abul Hasan
05-24-2011 08:39 AM
USE SOUND VI'S .... VI'S ARE PRESENT IN "GRAPHIC&SOUND".... USE PLAY FILE VI TO START WITH & THEN YOU CAN PLAY AROUND WITH OTHER VI'S.
05-24-2011 09:52 AM
Dear
Thanks a lot for your reply. I never used this sound VIs before. Can you show me a simple block diagram so I can understand and can do more things on it.
Best Regards
Muhammad Abul Hasan
05-24-2011 10:03 AM - edited 05-24-2011 10:04 AM
LOOK AT THIS AND TRY OUT, YOU SHOULD BE ABLE TO PLAY ".WAV" & "MP3" ..... IF YOU WANT TO PLAY DIFFERENT FORMAT THEN USE ACTIVE x & CALL WINDOWS MEDIA PLAYER AND PROGRAM ACCORDINGLY.
05-24-2011 10:26 AM
First of all ¨Systemcrash. You should not eat or drink while working with your computer. The keys can get sticky like your Caps Lock key are now.
In Labview it is NO functions for playing other sounds files than wav files. But you can at least in windows OS use ActiveX to embed a media player into Labview and also control it from Labview.
05-24-2011 11:00 AM
I believe the way I have told and way you have depicts one and the same regarding Active X, Keyboard sticky non sticky it shouldn't bother you, if the other person is able to understand something from the reply that's enough for me.
05-25-2011 08:09 AM
Ummm.... where did ActiveX come into this? The sound VIs don't use ActiveX.
http://www.simplehelp.net/2006/08/14/how-to-be-polite-while-youre-online-practicing-good-netiquette/
To poster: there are examples that ship with LabVIEW on how to play sound files. Have you looked at them? Help -> Find Examples.
05-25-2011 08:21 AM
Thanks for the link sir.
