play different wav files using case structure
sir,
i am trying to play Morse code .wav file for 3 different characters using a case structure. But i am getting an error of " LabVIEW: (Hex 0x12C5) Could not find the sound file."  can you suggest some solution and I think my VI will play the file continuously. instead can you provide me with some solution so that i plays once for every string input ?
thanks
Message 1 of 8
(3,061 Views)
Hi may,
as soon as I correct the file path for your WAVE files I can play the morse code sounds…
(Error 0x12C5 says "audio file not found"! Did you even read the error description?)
Message 2 of 8
(3,030 Views)
GerdW,
thanks for going through my VI.
I had altered the file path in order to compress it but as soon as i correct the file path it is showing me the error "LabVIEW:  (Hex 0x12CA) Cannot recognize sound format."
i have attached my VI with exact file path.
any solutions?
Message 3 of 8
(3,024 Views)
Your VI and .wav files work just fine for me.
The only thing is the timeout on the Output Sound needs to be larger because it gives a timeout value when it plays the B.wav file.
Message 4 of 8
(3,012 Views)
For me also its working fine. Can you provide the screen shot of the error?
Happy to Wire
Message 5 of 8
(2,994 Views)
For me also its working fine. What is exact problem? can you share any screen shots of the error.
Happy to Wire
Message 6 of 8
(2,993 Views)
here i have attached the screenshot of error that i am getting while i play the vi.
Message 7 of 8
(2,976 Views)
Hi may,
for us your WAV files work fine, but not for you.
So I guess the problem is with your computer…
Message 8 of 8
(2,968 Views)
