pixmap to imaq image
I want to be able to use the IMAQ analysis tools to analyse images aquired by other means then a vision camera, as in this case the web. I have some conversion problem however when I try to get the image into the IMAQ-image format.
I tried the unflatten pixmap connected to the 'IMAQ ArrayToColorImage' as in the attached .vi, but as you can see the 24 bit pixmap is not compatible with the u32 input of the IMAQ-vi.
Any suggestions of how to do this?
I managed to do it by saving the image as a jpeg and then loding it with the 'load image' IMAQ vi, but that seems like a very ugly way of doing it.
(4,377 Views)
Hi Mathias_P,
i have changed your vi a little bit and connected a constant to the image type input. Now it works. Hope it helps. Smiley Happy
Mike
Message Edited by MikeS81 on 04-28-2008 09:31 AM
(4,363 Views)
Aah, it needs the constant to know the picture format. Thanks.
The program looks really good now, I should learn som LV-aestetics Smiley Happy
ty again.
Mathias
(4,357 Views)
I'm on 2016 and am seeing the following response:
'IMAQ ArrayToColorImage' was not found.  Has this be deprecated.  Is there another more suitable VI?
(3,051 Views)
