11-04-2015 06:41 AM
hey , i have a problem with physical channels in the DAQ assistant .
I have pressure sensor , torque sensor and a flow sensor that i want to test them.
in other hand , i have the DAQ(USB-6001) , labview 2012 and NI-DAQmx 15.0.1 .
When i want to put analogue input in the DAQ assistant , the physical channels channels appears in "voltage ,temperature, current .." but don't appear in "pressure , torque and some others "
What do you think is the problem ?
11-04-2015 06:54 AM
I think the "problem" is that you are using the DAQ Assistant, which is designed as a "simple" approach to DAQ, hence is unsuited for even slightly-more-complex tasks. Read this excellent White Paper and replace the DAQ Assistant with a small amount of real DAQmx code to do exactly what you want to do.
11-04-2015 07:04 AM
11-04-2015 07:43 AM
I think you need to use a custom scale - I think the pressure/torque options are for devices that have a built-in bridge circuit. Since you're not using one of those devices, you need to read in the voltage from the sensors and use a custom scale to convert from Volts to Pressure/Torque/Flow.
11-04-2015 07:53 AM
All of your sensors are voltage measurements. You need to know how to convert those volts into your unit of measure. The other options are just there to make things easier for you. it's still generally a voltage measurement.
11-05-2015 08:50 AM
please can you tell me where exactly i should focus in this paper ? or can you give an example on how to convert from voltage to pressure or torque? i am new in this software.
thank you
11-05-2015 09:01 AM
LabVIEW has 100's of examples built-in. Go to Help -> Examples and search for DAQmx. You can probably search for 'custom scale' and get an example for that too!
11-05-2015 09:06 AM
11-05-2015 09:29 PM
i tried to create a virtual channel and look what happened ....
11-05-2015 11:10 PM
