performing a modal analysis and plotting an frf
I am carrying out a modal analysis on a composite plate. I am using a shaker to excite the plate. I have two accelerometers - one fixed over the shaker for the input signal and the other fixed to the plate for the output signal. I would like to carry out a modal analysis and observe the FFT or the FRF for this plate. I am pretty new to Labview and would like some advice on generating the FFT or the FRF plot and observe the peaks.
Thanks.
(4,106 Views)
According to your question I have the following information for you:
Please have a look at this documentation. With this information you should be able to use signal analysis in Labview
The Fundamentals of FFT-Based Signal Analysis and Measurement in LabVIEW and LabWindows/CVI
Modal Analysis in LabVIEW
Two-Sided, DC-Centered FFT
Fast Fourier Transform (FFT)
Please let me know if you have any questions.
Corné Westeneng
NI-Netherlands
(4,061 Views)
