Thank you for the response. In reading the File/Directory Info information in Labview Help it states that "If PATH specifies a directory, size indicates the number of items in the directory." ... given this statement it would seem that this approach would not work. The only other option I could think of was to use the List Folder vi then run the File/Directory Info vi on each of the file names adding them up as we went along then subtracting that from a known size (in this case I'm trying to gather the room left on an SD Card) ... herein lies the problem ... the size of the SD Card can be variable, so I was hoping there was an easier way to do this. Any other ideas or is this what I am left to work with?
Greycat
