pattern matching acquisition in ni HSDIO 6552
I want to acquire a data with help of ni HSDIO 6552 when particular word match on particular channel. I found pattern matching VI which matches the pattern that is formed from 1 bit from each specified channel but I want the pattern to be from 10 bits of one specific channel.
for example,I want to acquire data only when channel 5 matches 10 bit "101010111000"
Is it possible to do so? How?
Thank you.
(2,647 Views)
Accepted by topic author Mbgor
Can you try use Multi-sample pattern start trigger?
In example replace Start trigger Pattern Match to Multi-sample.
(2,624 Views)
