01-28-2008 05:35 PM
01-28-2008 10:24 PM
Hi CF,
I've passed data from LabVIEW to Java via a tcp/ip connection - that would be a bit better than the temporary text-file! Not sure about passing the VAR type, though. If VARiants have some universal representation, then maybe it can be unpacked on the Java side, otherwise, I'd consider serializing/passing simple numeric types.
In labview 8.2 I'm outputing two XY numbers as type VAR. I need to read these in another Javascript program I have written.
01-28-2008 10:57 PM
01-29-2008 02:57 PM
Check out this thread. Calling a VI as an ActiveX Object is an option for you. Try this command:
response = vi.GetControlvalue("Output")
Happy coding!
