Hello fellows, (using LabVIEW 8.5 full dev with WinXP)
I'm dealing with calling DLLs functions. So, I have the DLL code to build for passing from LabVIEW a table of char like this:
char table [ ] = {0x04, 0x0F, 0x04, 0x00,0x00,0xFA,0x00}
So I pass the data by creating a table of char in labview and select "Adapt to type" when passing this table in the calling DLL function node.
Then I wrote the data to a Pipe to be interpreted by the other program.
here is the c program:
extern "C" _declspec (dllexport) void test_Write_Event(HANDLE HandlePipe, char InputArray[255] ,char OutputArray[255],int size)
BOOL fileRead;
DWORD bytesWrite;
int i;
char *pEvent = "";
/* Copy the input array */
for(i = 0; i < size; i++)
pEvent[i] = InputArray[i];
OutputArray = InputArray;
//Write to pipe
fileRead = WriteFile(HandlePipe,
pEvent,
(size),
&bytesWrite, NULL);
I don't know if my data type adaptation is right ?? some help !
PS: the vi to test this DLL function attached
