pass a TCP socket as an input parameter to a VI
How do I pass a TCP socket as an input parameter to a VI?
I have a class with a method that does some operations on a TCP socket.  However, I can't figure out how to pass a TCP socket to it.
(2,792 Views)
Is this a LabVIEW class or are you trying to pass it to a DLL? If it is being passed to native LabVIEW code, simply use  TCP reference.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,780 Views)
Hi Mark, it is not a DLL. It is a LabVIEW NXG class I made.
Normally to pass parameters to a method you draw some control and check "On Connector Pane."  However, I don't know what type of control to use to represent a TCP connection.
(2,720 Views)
