I have the following problem:
I have a LabVIEW FPGA program that generates a incremental signal (with variable period and pulse width) on some digital output. As I want to count the generated pulses, I implemented in parallel a counter (UpDownCtr, SW Dir.vi - from the examples library) that reads directly the same digital line, using a Single-Cycle Timed Loop.
First I observed that my program was for example generating 9 pulses, and counting 11. Then I replaced the SCTL by a classic while Loop, but it still doesn't count properly; the only difference is, sometimes I have 10 pulses generated (instead of 9) for 11 counted.
Does someone know how to solve this problem ?
I thought about arbitration, but it is not possible to use it with digital input.
Would it be better to use some local variables ?
Or how can I synchronize both operations ?
Thanks in advance for the help,
Laurent
