pan y axe
hello,
is there any way to change the y- axe which is scaled by pan mode?
markus
(3,518 Views)
Markus,
you should be more precise in your question.
- What graph are you talking about (waveform chart/graph, XY-graph)?
- What do you understand by your expression "scale by pan"? I would asume autoscale here....
- What version of LabVIEW are you using?
- What is the "change" you are talking about? Color, size, distribution, min/max-value  etc.?
Norbert B.
NI Germany
Norbert
Expert: Geometry
(3,510 Views)
i use a waveform chart with four y- axes and my graph palette is visible. the right symbol on the graph palette is a hand.
my problem is that this hand only works with one y-axe. i'm not able to change the y-axe.
markus
(3,506 Views)
Markus,
i just checked with LV 8.2 and must confess that it is still not clear to me what the issue is. If i select the hand to move the chart around, all axes affected by the movement. Is this the behaviour you are seeing or not?
Norbert
Norbert
Expert: Geometry
(3,500 Views)
i attached an example with a waveform chart on it.
i use lv8.01 an there is only one axe which changes.
markus
(3,495 Views)
Hi Markus,
I experience the same problem when I assign different plots to different y-axes (as shown below).
I made a VI, which shows one solution, although I don't like it because it flickers.
Greets, Dave
Message Edited by daveTW on 09-04-2006 04:12 PM
Greets, Dave
(3,488 Views)
I've  tried out the vi you've attached.
But theres one problem.
the event structure only send one "new range".an array for every plot would be better.
Every plot gets the same range.
is there any other solution?
markus
(3,397 Views)
