06-16-2016 11:00 AM
I want to print text at certain positions on image captured using Vision Acquisition. I am thresholding the image to detect objects and then running overlay text in a loop to display the text beneath each object. At the end, I am getting the text written below the objects but the thresholded objects disappear ( the red markings). Why is this happening?
Solved! Go to Solution.
06-17-2016 03:47 AM
Could you please share your code...?
06-17-2016 08:19 AM
Threshold result - does it go into the same image as original? You should copy image to a separate buffer for processing and display overlay on original image.
