Can anybody help improve the response of the output in my simple counter vi?
The vi is used to count to two channels of linear encoders, when the sum of either channel or the sum of both channels reaches a desired value an output is created. My intention is to build a vi for a simple printing platform, so as the stage moves along its axis I can create a pulse which corresponds to a dot pitch
The stage moves at ~10mm/sec providing a counting rate of 2.5KHz (2500pulses in 10mm) I need to output every 20 pulses. Unfortunately for meL ; there is a delay on the output equivalent to 250ms or every 250pulses.
