01-12-2007 11:06 AM
01-15-2007 11:33 AM
The array subset function will allow you to extract a subset of your data array.
I'm not sure what version of LabVIEW you are using, but if it's 8.x then there are fitting functions you can use in the Mathematics -> Fitting palette. There are also functions in 7.x for this.
Together those functions should allow you to fit a function to a subset of your data.
For additional examples or drivers for devices, you should search ni.com, the developer zone, and/or more specifically the instrument driver resources.
Best Regards,
JLS
