05-26-2010 08:56 AM
I can use the pixlink driver SDK 4.2 in Labview 8.5 (8.2 samples from Pi). but there are always .ctl errors in Labview2009 as the screenshot below.
is there a new Pixelink dri for labview 2009 to be downloaded or how can I do with this problem?
thanks
Solved! Go to Solution.
05-28-2010 04:17 AM
Have you installed labview 2009 after you installed the driver? Can you please try to install the driver again and then check if still the same problem.
Stefan
11-26-2010 09:15 AM
Do you know what version of our SDK you are using?
I have also attached a sample projest supplied from one of our customers.
Thank you,
