numpy digitize function in labview
Is there a similar function/node in LabVIEW like python numpy digitize function??
(363 Views)
Hi dp,
so this numpy digitize() does mainly the same as the Threshold1DArray LabVIEW function…
(When I read/understand the description correctly.)
using LV2020 on Win8.1+cRIO
(349 Views)
I concur.
The "right : bool, optional" is missing though. This won't be trivial to fix. Probably check the remainder of result mod 1, and only add 1 to the quotient if it's !=0 (using the Sign function).
If the value is outside all bins the result will be different as well. You can probably make it act similar by adding a -Inf before all bins. This will return 0 if x is <bin[0], and 1 if it's in bin[1].
(322 Views)
