not possible to bind shared variable via Ethernet network
Hello!
I have computer A and B with windows xp, sp3 and labview 8.6, professional edition. Both computers are in the ethernet network. I like to exchanged data between two LV application using shared variables. I create shared variable (network published) on both computers.
The problem is, that is in shared variable properties not possible to bind variable from remote computer to the local computer. In first step there are even no possible to see any computer in the network. After computer registration (tools->shared variable->Register computer)
i see the remote computer, but without any shared variable.
Do you have any idea how to solved this problem?
Thank you for the answers.
(2,678 Views)
On the PC that is hosting the shared variables, has the shared variable library been deployed yet before you try to bind the other PC's variables to the network published shared variables?
(2,663 Views)
Hello !
Yes! I deployed the libraliy with the shared variables.
(2,661 Views)
I deploy shared variable, but there are still not possible to establish connection.
(2,649 Views)
Accepted by topic author Toni2
Hi :),
check this link, maybe it can help you.
(2,631 Views)
