not finding outputs from statistic operations in measurement file
Hi
I am using express VI's in my  program as i am quite new to labview. There is a simple solution to my problem (i think). I am using SCXI's 1520 (8ch) and 1100 (32ch) for my data aquisition. I have one daq assistant but i want data to be collected by two separate measurement files. One of the measurement files is collecting all the data i need i.e. i can can see all my desired outputs in the measurement file (25no.). But with the other measurement file its only reading 8 outputs instead of the circa 30outputs i am expecting.Please if anyone can help me i will really appreciate it. I have attached my VI
(2,354 Views)
Hi EVXSL6,
Welcome to the NI Discussion Forums!
Could you clarify which 'Write to Measurement File' is only writing 8 signals to file and possibly provide us with an example of this?
It would also be worth probing the signal line before it's logged to ensure it has all of the expected data on (Right Click the wire -> Probe).
Could you also confirm that the data is definately not present, rather than being formatted in some unexpected way?
Chris (CLED, CLA, CTA)
Applications Engineering Specialist
(2,324 Views)
