none of ai, te0 & te1 clock source work except OnbordClock for cDAQ9174?
That's almost correct. Put ActiveChans and AI.ADCTimingMode in the same property node (drag the bottom to select two properties) and wire it into your task, and I think it should work. ActiveChans has to be first because it applies to all of the properties below it in the same node.
Brad
Brad Keryan
NI R&D
Message 11 of 14
(754 Views)
Thank you very much Brad. Smiley Very HappyThanks to your step-by-step instruction, now the VI works with 2 analog input synchronised.
Message 12 of 14
(751 Views)
Thank you very much for your enlightening question!
Message 13 of 14
(714 Views)
I simulate two devices (cDAQ9174+9206) and run Acq Voltage-Clk Select.vi. It does work.
Message 14 of 14
(713 Views)
