04-13-2006 09:28 AM
04-13-2006 09:30 AM
04-14-2006 05:21 PM
Hello Oliboiss,
What sampling rate are you using? Does this problem go away if you decrease your sampling rate? What type of SCXI module do you have your LVDT connected to? What SCXI modules are in your system, and which are you using as your communicating module? Check that which ever module you have listed in Measurement and Automation Explorer (MAX) as your communicating module, is the module that actually has a cable connected to it if you are using a stand alone SCXI chassis and not a SCXI/PXI combo chassis.
Laura
04-20-2006 09:25 AM
04-20-2006 10:11 AM
04-20-2006 10:15 AM
