no sensor detected/ possible serial communication issue
Hi GerdW,
Thanks a lot for your help with my privious question, More or less i have managed to create a .vi to get the data from the TPG 261, after i will move to the TPG 256A. It does work, however I would like to create a .exe to be able to use in a different PC. I have created a Start and Stop buttom, for the .exe but they do not work at all, what am i doing wrong? Thanks a lot for your help.
Message 11 of 21
(2,120 Views)
Hi Chispi23,
I´m trying to read data from TPG 261 on my LabView project but I can´t. It always shows 0 on the pressure read, while on the TPG 261 display shows different values.
I can´t open your file because I have a previous version of LabView.
Have you managed to read the pressure value from TPG 261? Do you know any reasson why I´m not managing to do it?
Thanks!!
Message 12 of 21
(2,087 Views)
yes, i did manage, the file i did attach should work. Send me your code and i will have a look at it.
Chispi
Message 13 of 21
(2,077 Views)
Hi Chispi,
I tried lots of different LabView files that should work, but the program always stucks when it has to read data just after you write the command (PRX, COM, etc). I´ve never managed to read that value.
I don´t know if the problem is in the comunication between the computer and TPG 261. Do you know if there is any way to prove that?
Thank you very much!!
Message 14 of 21
(2,056 Views)
hi,
If you send me one of your files i can check if it does work or not!!!
Cristobal
Message 15 of 21
(2,051 Views)
Hi Cristobal,
I post here the VI file.
Thank you very much!!!!:)
Message 16 of 21
(2,048 Views)
Hi Bortx,
I have just checked your file and in my pc it seems to work.
Chispi
Message 17 of 21
(2,031 Views)
Hi Cristobal,
Do you think I need any specific drivers for the TPG 261 to work? Might the problem be there?
I really don´t know what else to do😂
Thanks again!!!!😀
Message 18 of 21
(2,027 Views)
You need the visa driver.
Message 19 of 21
(2,023 Views)
I already have that driver.
Anyway, thank you very much for your help.
Message 20 of 21
(2,018 Views)
