nidmm_32.dll nidcpower_32 niswitch_32.dll Will not load if network not connected??? Work find when Network is connected
Running LabVIEW 2018 SP1
daqmx 18.5
I have a strange problem that is likely related to company network or security settings but I'm hoping someone might have some advice.  I have a tester that is on a stand-alone network.  When the tester is connected to the network niDMM, niDCpower, and niSwitch VIs located in instr.lib work fine.  When the tester is disconnected from the network I get
Error loading nidmm_32.dll
The network path was not found.
For each of the above dlls.  I have looked through tons of registry settings and it looks like the paths are all correct and link to C:\Program Files (x86)\IVI Foundation\IVI\Bin which is where each of these dlls reside.  I can't figure out why the LabVIEW can't load the dlls with the network disconnected unless there is some secret network security setting preventing it.
Any advice would be greatly appreciated
Message 1 of 1
(981 Views)
