nidmfpan.exe Does Not Do Anything?
Hello All,
I have been trying to run nidmfpan.exe /devid:dev1 (where I have replaced dev1 with the actual device id), but nothing would happen after I run it from Run.  Does the device in question has to reside the the niDAQmx to work?  The test panel I want to run is the one highlighted in the picture attached.
(3,212 Views)
Hi Bladhart,
Thanks for the post and I hope your well today.
I am afraid the nidmpan.exe only works for devices which reside under NI-DAQmx.(which use the NI-DAQmx).
What version of DAQmx are you using?
I assume the test panel works manually?
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,189 Views)
I use DAQmx 8.7.
I guess kinda had to do a bit of config to get the test panel to show what I wanted it to show.
(3,171 Views)
