ni-visa on ubuntu 18.04 (64 bit)
Dear all,
I've installed labview on ubuntu 64bits successfully but I'm facing on a problem relative to the visa driver.
Basically I need the serial connection to use VIs in general but the VISA drivers are not working.
I've installed packages from the repository here but when the visaconf tool crash as soon as I open it.
On the NI official  website there's no support on this.
Anyone has a suggestion?
Thanks in advance
(2,167 Views)
same issue for me.
When I run the visaconf command, after a bit I get this reply on the terminal
libnipalu.so failed to initialize
Verify that nipalk.ko is built and loaded.
Aborted (core dumped)
has anyone solved this unexpected error?
(2,085 Views)
